Topics
These steps explain how to confirm that the Nagios server is receiving SNMP Trap traffic destined for it on the UDP port 162.
In this example, the following applies:
The purpose of this test is to confirm that the network traffic is hitting the Nagios XI server. TCP dump displays the lower level of network traffic before it is intercepted by the Operating System (OS) firewall rules.
The OS firewall rules are not evaluated yet and hence this test allow you to clearly determine if this traffic is hitting the Nagios XI server.
If your tests show that no traffic is being received then there must be other firewall(s) between the sending device and the Nagios XI server that are blocking the traffic.
Establish an SSH session to the Nagios server that receives SNMP Traps. Execute the following command to install the tcpdump program, depending on your OS:
RHEL | CentOS | Oracle Linux
yum -y install tcpdump
**Debian | Ubuntu
apt-get install -y tcpdump
Wait while tcpdump is installed/updated.
Execute the following command:
tcpdump src host 10.25.5.20 and udp dst port 162 and dst host 10.25.5.30
When an SNMP Trap is received it should product output like:
10:57:34.879662 IP snmpsender.domain.local.40410 > snmpreceiver.domain.local.snmptrap: V2Trap(180) system.sysUpTime.0=144810 S:1.1.4.1.0=E:20006.1.7 E:20006.1.3.1.2="CentOS" E:20006.1.3.1.6="Users" E:20006.1.3.1.7=0 E:20006.1.3.1.17="USERS OK - 0 users currently logged in"
When you have finished watching the network traffic press CTRL + C to kill tcpdump.
tcpdump -n src host 10.25.5.20 and udp dst port 162 and dst host 10.25.5.30
10:59:17.614465 IP 10.25.5.20.43471 > 10.25.5.30.snmptrap: V2Trap(185) .1.3.6.1.2.1.1.3.0=155084 .1.3.6.1.6.3.1.1.4.1.0=.1.3.6.1.4.1.20006.1.7 .1.3.6.1.4.1.20006.1.3.1.2="CentOS" .1.3.6.1.4.1.20006.1.3.1.6="Users" .1.3.6.1.4.1.20006.1.3.1.7=1 .1.3.6.1.4.1.20006.1.3.1.17="USERS WARNING - 1 users currently logged in"
If you receive this message when trying to execute tcpdump:
tcpdump: NFLOG link-layer type filtering not implemented
Then you will need to define the interface name with the -i xxx argument, for example:
tcpdump -i ens32 src host 10.25.5.20 and udp dst port 162 and dst host 10.25.5.30
With these steps you will be able to confirm that the Nagios server is correctly receiving SNMP Trap UDP traffic on port 162 from a remote server.
Your next troubleshooting step would be to confirm the firewall rules are in place.
© All rights reserved. 2026
